Mercedes W123 Glow Plug Test Technique
  1. Mercedes W123 Glow Plug Test Technique, Mercedes W123 Glow Plug Test Technique: step 1, image 1 of 1
    • To perform this method of testing, you will need a reliable 12v power source. You could use a spare 12v battery and jumper cables. In this case, a battery "jumper" box was used.
    • If you are testing a glow plug that is new from the box, you can begin here.
    • If you are testing a plug that is currently in your engine to see if it is the bad plug, you will need to first remove it; see the glow plug replacement guide for advice on this process.
    • Start the test by gripping the body of the glow plug with the negative cable clamp.
  2. Mercedes W123 Glow Plug Test Technique: step 2, image 1 of 1
    • Then attach the positive clamp to the threaded end of the glow plug. Be careful to not let the positive and negative clamps touch.
    • Pictured is a good, brand new Bosch glow plug lighting up nice and hot at the very tip. This is how the plugs should all perform.
    • Be extremely careful during this process! Never ever touch the tip, or place it on a flammable surface just after testing. The tip can reach temperatures over 1000F!
  3. Mercedes W123 Glow Plug Test Technique: step 3, image 1 of 1
    • Shown here is a used glow plug that is not working quite right, despite glowing at the tip. The tip was slow to light compared to the new plug. You can also see that it is covered in carbon; it's a reminder that you'll want to ream the glow plug hole in the pre-chamber before installing a new one.
  4. Mercedes W123 Glow Plug Test Technique: step 4, image 1 of 1
    • Shown here is a bad glow plug. It did not glow at all despite 12v being directly applied. This was the main culprit in this particular car's rough cold starts.
When done testing, replace any bad glow plugs.
5 other people completed this guide.
Nicolas Siemsen
39,040 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,535 Guides authored
2 Comments
Muy Util su guia muchas gracias!!
Pippenpy - Reply
Thank you for your work. Very helpful.
Vitaliy Khutko - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 29
All Time: 7,081
