Introduction
There are many systems in your car that depend on a well-performing battery. Since modern batteries are sealed they are fairly low maintenance items. However, they should not be completely ignored. Learn to keep yours performing well.
The battery on diesel W123 cars is located in the far rear left corner of the engine bay, as you face it from the front of the car.
This battery is in fairly good shape, but has not been maintained in several years and has gotten dirty and could use some love...
To begin, disconnect the positive and negative battery terminals. This will be covered further in Step 3.
Make note of which terminal is which. On many new cars, the positive terminal is marked with red while the negative is black.
On a W123 however you may need to depend on the small "+" sign to find the positive terminal.
Use a crescent wrench to loosen the nuts on the battery terminals. Do not remove the nut fully, just loosen it enough to remove the terminal. On W123's, this nut is likely a 13mm.
Pull the terminals off, starting with the Negative "-" terminal, then the Positive "+" terminal.
Use a soft metal brush, like the brass brush shown, to clean any corrosion off of the inside of the terminal. Follow this up with a spray of electric contact cleaner.
Use a soft metal brush to clean any corrosion or dirt from the battery posts.
Then use some mild cleaner on a damp shop towel to wipe down the rest of the battery of dirt and corrosion.
If your battery is really dirty, and has lots of corrosion, consider purchasing a spray can of battery cleaner designed for heavier cleaning.
Reconnect the terminals to their appropriate posts and enjoy the fresh clean battery!
Optional but recommended - cover the battery terminals with a light coat of dielectric silicone grease after tightening them in place. This will help prevent future corrosion.
