Introduction
It's a very common issue that newer vehicles' headlamps are brighter than the old timers'. This guide will help you update your bulb.
Locate the bottom screw which holds the metal frame around the lamp and unscrew it. Because there are no other screws to hold it, gently lift the frame upwards to unlock the pin on the top.
Carefully unplug the headlamp socket, and then rotate the metal ring, which holds the bulb to the body. Then, pull the bulb out slowly.
After replacing the new bulb, follow the reverse order of disassembly. Before you fix the metal frame, align your headlamp beam.
To do so, locate the screws on the headlamp cover body, which are covered with a plastic frame. The outer-side screw aligns the fog lamp and the inner-side screw aligns the headlamp. Start your car, turn on the fog lamps, and align them; then, turn off the fog lamps and align the headlamps.
