Oct 15, 2015 - 11:18:51
Oct 08, 2015 - 11:36:32
Oct 08, 2015 - 11:20:54
Oct 08, 2015 - 11:19:57
Oct 08, 2015 - 11:19:43
Oct 08, 2015 - 11:18:51
Oct 08, 2015 - 11:18:37
Oct 08, 2015 - 11:18:16
Oct 08, 2015 - 11:17:31
Oct 08, 2015 - 11:15:55
Oct 08, 2015 - 11:15:36
Oct 08, 2015 - 11:14:50
Oct 02, 2015 - 08:46:41
Mar 17, 2014 - 11:41:01
Mar 17, 2014 - 11:40:58
Mar 17, 2014 - 11:39:54
Mar 17, 2014 - 11:39:52
Mar 07, 2014 - 11:38:07
Mar 07, 2014 - 10:24:45
Mar 07, 2014 - 10:12:09
Mar 07, 2014 - 10:11:53
Mar 07, 2014 - 10:11:34
Mar 07, 2014 - 10:11:14
Mar 07, 2014 - 10:04:36
Mar 07, 2014 - 09:29:11
Mar 07, 2014 - 09:24:50
Mar 07, 2014 - 09:24:21
Mar 07, 2014 - 09:23:35
Mar 07, 2014 - 09:22:43
Mar 07, 2014 - 09:22:13
Mar 07, 2014 - 08:55:02
Mar 07, 2014 - 08:54:38
Mar 07, 2014 - 08:53:18
Mar 07, 2014 - 08:52:04
Mar 07, 2014 - 12:35:47
Mar 07, 2014 - 12:35:15
Mar 07, 2014 - 12:32:46
Mar 07, 2014 - 12:32:15
Mar 07, 2014 - 12:32:14
Mar 07, 2014 - 12:18:23
Mar 07, 2014 - 12:17:59
Mar 07, 2014 - 12:16:03
Mar 07, 2014 - 12:11:48
Mar 06, 2014 - 11:41:19
Mar 06, 2014 - 11:40:53
Mar 06, 2014 - 11:40:28
Mar 06, 2014 - 11:40:04
Mar 06, 2014 - 11:39:16
Mar 06, 2014 - 11:37:27
Mar 06, 2014 - 11:37:03
Mar 03, 2014 - 02:12:13
Mar 03, 2014 - 02:11:29
Mar 03, 2014 - 11:48:38
Mar 01, 2014 - 01:22:11
Mar 01, 2014 - 01:19:27
Mar 01, 2014 - 01:17:43
Mar 01, 2014 - 01:07:01
Mar 01, 2014 - 01:01:14
Feb 28, 2014 - 02:54:22
Feb 28, 2014 - 02:51:57
Feb 28, 2014 - 02:47:14
Feb 28, 2014 - 02:31:50
Feb 28, 2014 - 02:27:59
Feb 28, 2014 - 02:27:20
Feb 28, 2014 - 02:26:38
Feb 28, 2014 - 02:26:09
Feb 27, 2014 - 01:45:21
Feb 27, 2014 - 01:44:44
Feb 27, 2014 - 01:42:30
Feb 27, 2014 - 12:59:43
Feb 27, 2014 - 12:57:33
Feb 27, 2014 - 12:55:33
Feb 27, 2014 - 12:55:09
Feb 27, 2014 - 12:50:24
Feb 27, 2014 - 12:46:47
Feb 27, 2014 - 12:45:41
Feb 27, 2014 - 12:44:03
Feb 27, 2014 - 12:40:27
Feb 27, 2014 - 12:03:45
Feb 26, 2014 - 11:46:10
Feb 26, 2014 - 11:45:42
Feb 26, 2014 - 10:13:44
Feb 26, 2014 - 08:53:57
Feb 26, 2014 - 08:42:06
Feb 26, 2014 - 08:40:24
Feb 26, 2014 - 08:39:48
Feb 26, 2014 - 08:24:56
Feb 26, 2014 - 06:10:04
Feb 26, 2014 - 06:07:32
Feb 26, 2014 - 06:02:44
Feb 26, 2014 - 05:36:25
Feb 26, 2014 - 05:33:43
Feb 26, 2014 - 05:32:15
Feb 26, 2014 - 05:30:25
Feb 26, 2014 - 05:28:03
Feb 26, 2014 - 05:27:32
Feb 26, 2014 - 05:25:26
Feb 26, 2014 - 03:33:25
Feb 26, 2014 - 03:23:28
Feb 26, 2014 - 03:21:29
Feb 26, 2014 - 03:20:47
Feb 26, 2014 - 03:20:02
Feb 26, 2014 - 03:18:02
Feb 25, 2014 - 07:05:54
Feb 25, 2014 - 07:05:05
Feb 25, 2014 - 02:58:12
Feb 25, 2014 - 02:57:11
Feb 25, 2014 - 02:56:55
Feb 25, 2014 - 02:51:16
Feb 25, 2014 - 02:49:40
Feb 25, 2014 - 02:39:17
Feb 25, 2014 - 02:36:48
Feb 25, 2014 - 02:17:07
Feb 24, 2014 - 02:59:50
Feb 24, 2014 - 02:59:28
Feb 24, 2014 - 02:59:21
Feb 24, 2014 - 02:59:16
Feb 24, 2014 - 02:59:08
Feb 24, 2014 - 02:58:21
Feb 24, 2014 - 02:56:47
Feb 24, 2014 - 02:54:13
Feb 24, 2014 - 02:52:42
Feb 24, 2014 - 02:49:18
Feb 24, 2014 - 01:44:05
Feb 24, 2014 - 01:43:24
Feb 24, 2014 - 01:42:22
Feb 24, 2014 - 01:41:27
Feb 24, 2014 - 01:41:05
Feb 24, 2014 - 01:36:53
Feb 24, 2014 - 01:36:41
Feb 24, 2014 - 01:36:18
Feb 24, 2014 - 01:35:17
Feb 24, 2014 - 01:34:41
Feb 24, 2014 - 01:34:05
Feb 24, 2014 - 01:33:53
Feb 24, 2014 - 01:32:42
Feb 24, 2014 - 01:31:53
Feb 24, 2014 - 01:30:51
Feb 24, 2014 - 01:30:34
Feb 24, 2014 - 01:29:53
Feb 24, 2014 - 01:29:37
Feb 24, 2014 - 01:28:33
Feb 24, 2014 - 01:27:41
Feb 24, 2014 - 01:27:36
Feb 24, 2014 - 01:26:53
Feb 24, 2014 - 01:25:54
Feb 24, 2014 - 01:25:09
Feb 24, 2014 - 01:24:09
Feb 24, 2014 - 01:23:51
Feb 24, 2014 - 01:22:12
Feb 24, 2014 - 01:21:56
Feb 24, 2014 - 01:21:46
Feb 24, 2014 - 01:21:41
Feb 24, 2014 - 01:21:31
Feb 24, 2014 - 01:21:24
Feb 24, 2014 - 01:21:18
Feb 24, 2014 - 01:20:47
Feb 24, 2014 - 01:20:39
Feb 24, 2014 - 01:20:22
Feb 24, 2014 - 01:19:59
Feb 24, 2014 - 01:19:46
Feb 24, 2014 - 01:18:22
Feb 24, 2014 - 01:17:04
Feb 24, 2014 - 01:12:39
Feb 24, 2014 - 01:11:18
Feb 24, 2014 - 01:05:38
Feb 22, 2014 - 02:15:56
Feb 22, 2014 - 02:15:55
Feb 22, 2014 - 02:09:22
Feb 22, 2014 - 01:45:40
Feb 22, 2014 - 01:45:39
Feb 22, 2014 - 01:39:01
Feb 22, 2014 - 01:39:00
Feb 22, 2014 - 01:32:56
Feb 22, 2014 - 01:32:55
Feb 22, 2014 - 01:22:50
Feb 22, 2014 - 01:22:49
Feb 22, 2014 - 01:16:20
Feb 22, 2014 - 01:16:19
Feb 22, 2014 - 01:08:38
Feb 22, 2014 - 01:08:37
Feb 22, 2014 - 01:06:49
Feb 22, 2014 - 01:04:27
Feb 22, 2014 - 01:04:26
Feb 22, 2014 - 12:58:50
Feb 22, 2014 - 12:50:18
Feb 22, 2014 - 12:46:10
Feb 22, 2014 - 12:45:33
Feb 22, 2014 - 02:52:09
Feb 21, 2014 - 07:09:04
Feb 21, 2014 - 07:03:45
Feb 21, 2014 - 06:53:44
Feb 21, 2014 - 06:53:43
Feb 21, 2014 - 06:31:31
Feb 21, 2014 - 06:26:15
Feb 21, 2014 - 06:25:36
Feb 21, 2014 - 06:16:42
Feb 21, 2014 - 06:16:25
Feb 21, 2014 - 06:13:36
Feb 21, 2014 - 06:12:37
Feb 20, 2014 - 02:56:09
Feb 20, 2014 - 02:52:43
Feb 20, 2014 - 02:27:59
Feb 19, 2014 - 01:55:02
Feb 19, 2014 - 01:52:37
If you need to replace the back panel of the Minimove boombox, follow the steps from this guide. This guide will involve moderate disassembly of the device, including the removal of the back covering and base.
Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
It may be helpful to pull the plastic covers out with your fingers once the top of the cover has been revealed by using the plastic opening tool.
To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed.
After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
