Measuring Current with Clamp Meter and AC Line Splitter
View statistics:
Past 24 Hours:
Past 7 Days:
26
Past 30 Days:
100
All Time:
463
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This wiki explains how to use a clamp meter and the AC line splitter to measure the current draw of a device under test.
    1. Measuring Current with Clamp Meter and AC Line Splitter, Measuring Current with Clamp Meter and AC Line Splitter: step 1, image 1 of 3 Measuring Current with Clamp Meter and AC Line Splitter, Measuring Current with Clamp Meter and AC Line Splitter: step 1, image 2 of 3 Measuring Current with Clamp Meter and AC Line Splitter, Measuring Current with Clamp Meter and AC Line Splitter: step 1, image 3 of 3
      • Connect AC Line Splitter to power Source.
      • Connect device to test to AC line splitter.
      • On Multimeter, select AC Current.
      Ask FixBot
    2. Measuring Current with Clamp Meter and AC Line Splitter: step 2, image 1 of 2 Measuring Current with Clamp Meter and AC Line Splitter: step 2, image 2 of 2
      • Clamp meter on the x1 loop of the line splitter for most devices. Only use the x10 loop if you are testing a very low current device.
      • Turn on the device you are testing.
      • Read the current indicated on your meter.
      • You are done with this procedure. Turn off the device you are testing and disconnect your equipment.
      Ask FixBot
Using this process can allow you to measure how much current a device is drawing which can aid in troubleshooting. A device drawing more than it's rated amount of current can be an indication of a problem.
rickwag
1,906 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 100
All Time: 463
