Maytag Washing Machine Drain Pump Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
47
Past 30 Days:
193
All Time:
748
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to replace the drain pump and filter assembly in a Maytag front-load washing machine that won't drain, leaves water in the tub, or shows an FO2 error code. The drain pump moves wash water out during drain and spin. Replace it if cleaning debris from the pump doesn't restore draining, or if the pump has failed from wear. This guide was written for a front-load Maytag washer with a lower access panel, so some mounting details may differ on other models.
Parts
Tools
      • Unplug the washer before removing any covers or touching the pump wiring.
      • Turn off the water supply if you need to move the washer or disturb the fill hoses.
      • Keep the pump connector and nearby wiring dry throughout the repair.
      • Set a large bowl and towels under the front of the washer to catch water from the pump and hoses.
      • If the tub is full, expect much more water than the pump body alone can hold.
      Ask FixBot
      • Check for an FO2 code, water left in the tub, or a Drain and Spin cycle that counts down without pumping.
      • Debris in the pump can rub the impeller and cause drain errors or pump failure.
      • Replace the drain pump if cleaning debris doesn't restore draining, or if the pump has failed from age.
      • Use the washer model number to confirm the replacement pump matches before installing it.
      Ask FixBot
      • Use a 1/4 inch nut driver to remove the three screws from the lower front cover.
      • Open the lower drawer, lift it, and remove it from the washer.
      • Set the screws aside where they won't get lost.
      Ask FixBot
      • Place a large bowl directly under the drain-pump area.
      • Squeeze the two clips on the nearby connector retainer and move it out of the way.
      • The lower drawer has drain holes, but don't rely on it to catch the water.
      • Keep towels nearby because the pump can still drain water even if the tub looks empty.
      Ask FixBot
      • Remove the screw through the rubber grommet if your pump uses one.
      • For a pull-tab mount, press the pump upward and pull the front tab forward to release it.
      • Slide the rear rubber feet off the mount and pull the pump forward.
      • Unclip the pump wire from its holder.
      • Squeeze the two tabs on the connector cover, lift the cover, and unplug the pump connector.
      • Keep the electrical connector dry and unplugged until all hose work is finished.
      Ask FixBot
      • Position the loose pump so the cleanout cover points toward the bowl.
      • Slowly loosen the cleanout cover to start draining water.
      • Don't remove the cleanout cover all at once if the tub is full.
      • Empty the bowl as needed until the water stops flowing.
      • Retighten the cleanout cover if you loosened or removed it.
      Ask FixBot
      • Use pliers or tongue-and-groove pliers to squeeze the first hose clamp.
      • Slide the clamp back on the hose.
      • Work the hose off the pump fitting.
      • Repeat the clamp and hose removal for the second hose.
      • Remove the drain pump from the washer.
      • The hose clamps are usually the hardest part of this repair because access is tight.
      Ask FixBot
      • Compare the replacement drain-pump and filter assembly with the old pump before installing it.
      • Confirm the pump matches the washer model number.
      • Check the mount layout before installation.
      • The rear tabs fit under the back legs, the front mount fits under the rubber loops, and the pull tab locks over the front mount.
      • Common compatible numbers for this pump style include 280187, 8181684, and 285998.
      Ask FixBot
      • Slide the rear mounting tabs of the new pump into the back slots.
      • Press the front feet into the front mount.
      • Pull the front tab into place so it locks over the pump mount.
      • A little movement is normal because the pump sits on rubber mounts.
      Ask FixBot
      • Use pliers or tongue-and-groove pliers to compress the clamp on the rear hose.
      • Slide the rear hose fully over the rear pump fitting before releasing the clamp.
      • Release the clamp only after the hose is fully seated.
      • Compress the clamp for the second hose and slide that hose fully over the front pump fitting.
      • Release the second clamp after the hose is fully seated.
      • Fully seated hoses help prevent leaks at the pump housing.
      Ask FixBot
      • Plug the pump connector back into its matching socket.
      • Close the connector cover.
      • Clip the wiring back into its retainer so it stays away from the pump and hoses.
      • Reinstall the clips that hold the connector retainer in place.
      Ask FixBot
      • Leave the lower access cover off so you can see the pump during testing.
      • Dry the area under the pump and hoses with a towel.
      • Restore power and run a cycle that fills briefly and drains.
      • Watch both hose connections, the cleanout cover, and the pump housing for leaks.
      • Expect some air noise or cavitation when the new pump first primes.
      • The washer should pump water out strongly after the pump primes.
      • Unplug the washer before touching the pump area if you see a leak.
      Ask FixBot
      • Cancel the test cycle and unplug the washer.
      • Reinstall the lower drawer or access cover.
      • Use a 1/4 inch nut driver or Torx screwdriver to reinstall the three screws.
      • Run a Drain and Spin cycle and confirm the FO2 code doesn't return.
      Ask FixBot
Run one complete wash and drain cycle after the repair, and check the floor under the washer for any signs of water. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 47
Past 30 Days: 193
All Time: 748
