Maytag Refrigerator Control Board Replacement
Video Guide
This guide was transcribed from a YouTube video.
      • Unplug the refrigerator from the wall outlet.
      • WARNING: Unplugging is required because the control board area can have live voltage when powered.
      Ask FixBot
      • Move the refrigerator away from the wall so you can access the back.
      • Use a 1/4 inch nut driver to remove the four screws securing the rear metal panel.
      • Remove the panel to expose the control board area.
      • Sheet-metal panels can be sharp, so wear work gloves and handle the panel carefully.
      Ask FixBot
      • Check for a plastic cover over the control board and remove it if present.
      • Some units don’t have this plastic cover.
      Ask FixBot
      • Disconnect the four Molex connectors from the control board.
      • Press the small locking tab on each connector, then pull the connector straight out.
      • Caution: Pull on the connector housing, not the wires, to avoid damaging the harness.
      • Caution: Avoid static discharge into the new board by touching an unpainted metal surface before handling it.
      Ask FixBot
      • Use a flathead screwdriver to depress the two retention tabs holding the control board in place.
      • Depress the top tab and the bottom tab, then pull the control board out of its mount.
      • Do not pry against other components or wiring while releasing the tabs.
      Ask FixBot
      • Position the new control board in the mounting area.
      • Slide the board under the two guides on the right side.
      • Press the board inward until it snaps into place.
      • Use a flathead screwdriver to push the tabs down if the board won’t seat easily.
      • Listen and feel for the board to pop into place on the retention tabs.
      Ask FixBot
      • Reconnect all Molex connectors to the new control board.
      • Press each connector in until it fully seats and the lock engages.
      • Reinstall the plastic cover if your refrigerator has one.
      • Reinstall the rear metal panel and its four 1/4 inch hex-head screws.
      Ask FixBot
      • Plug the refrigerator back into the wall outlet.
      • Wait about two to three minutes for the refrigerator to boot.
      • Check the front interface for a programming-required code such as PE0000.
      Ask FixBot
      • Press and hold the Door Alarm button.
      • Within three seconds, press and hold the down arrow on the Freezer Temperature button.
      • Release the Door Alarm button while continuing to hold the Freezer Temperature button until programming unlocks.
      Ask FixBot
      • Release the buttons.
      • Press the down arrow on the Freezer Temperature button repeatedly until a small dot appears on the interface.
      • The dot indicates that you are actively in the programming system.
      Ask FixBot
      • Open the refrigerator door and find the nameplate with the model and serial number.
      • Look on the upper right side for the nameplate on this style of refrigerator.
      • Locate the programming code on the nameplate, since it varies by model.
      Ask FixBot
      • Press up on the Refrigerator Temperature button to set the first digit.
      • Use the small dot to track which digit you are currently editing.
      • Press up on the Freezer Temperature control to move the dot to the next digit.
      • Repeat for the remaining digits until the full code matches the nameplate.
      Ask FixBot
      • Press and hold the down arrow on the Freezer Temperature button until the code flashes.
      • Press and hold the down arrow on the Freezer Temperature button again to confirm the code.
      • Wait for the refrigerator to quickly return to normal operating mode.
      Ask FixBot
      • Verify the front interface responds and the temperature settings can be adjusted.
      • Confirm the programming-required error code is no longer displayed.
      Ask FixBot
If the interface is responsive and the refrigerator returns to normal mode after programming, the control board replacement and setup are complete. Recheck any connector that isn’t fully seated if the interface stays blank or the programming code won’t clear. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,143 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 109
All Time: 579
