Mayflash Arcade Stick F300 USB Cable Replacement
    1. Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: step 1, image 1 of 3 Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: step 1, image 2 of 3 Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: step 1, image 3 of 3
      • Flip the controller upside down so that the metal panel is facing you.
      • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
      • Once all screws are removed, lift off the panel.
      Ask FixBot
    1. Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: step 2, image 1 of 2 Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: step 2, image 2 of 2
      • Remove the four 10 mm truss head screws securing the PCB to the plastic outer casing using a Phillips #1 screwdriver.
      Ask FixBot
    2. Mayflash Arcade Stick F300 USB Cable Replacement: step 3, image 1 of 3 Mayflash Arcade Stick F300 USB Cable Replacement: step 3, image 2 of 3 Mayflash Arcade Stick F300 USB Cable Replacement: step 3, image 3 of 3
      • Use a hair dryer or heat gun to soften the glue holding the USB cable into the socket on the PCB.
      • It should take less than a minute for the glue to be soft enough to remove. Do not overheat the circuit board.
      • Use a metal spudger to gently remove the softened glue.
      • Remove the cable from the socket
      Ask FixBot
    3. Mayflash Arcade Stick F300 USB Cable Replacement: step 4, image 1 of 3 Mayflash Arcade Stick F300 USB Cable Replacement: step 4, image 2 of 3 Mayflash Arcade Stick F300 USB Cable Replacement: step 4, image 3 of 3
      • Slide the strain relief segment of the USB cable out of the plastic outer casing.
      • Remove the cable.
      Ask FixBot
Jess Anderson
342 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 47
All Time: 624
