Mayflash Arcade Stick F300 Microswitch Replacement
    1. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: step 1, image 1 of 3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: step 1, image 2 of 3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: step 1, image 3 of 3
      • Flip the controller upside down so that the metal panel is facing you.
      • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
      • Once all screws are removed, lift off the panel.
      Ask FixBot
    1. Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: step 2, image 1 of 2 Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: step 2, image 2 of 2
      • Remove the four 9 mm truss head screws fastening the clear plastic square joystick gate to the casing underneath using a Phillips #1 screwdriver.
      Ask FixBot
    2. Mayflash Arcade Stick F300 Microswitch Replacement: step 3, image 1 of 3 Mayflash Arcade Stick F300 Microswitch Replacement: step 3, image 2 of 3 Mayflash Arcade Stick F300 Microswitch Replacement: step 3, image 3 of 3
      • Gently push back on each of the four black locking tabs securing the joystick gate to the casing.
      • Remove the joystick gate.
      Ask FixBot
    3. Mayflash Arcade Stick F300 Microswitch Replacement: step 4, image 1 of 2 Mayflash Arcade Stick F300 Microswitch Replacement: step 4, image 2 of 2
      • Lift the chosen microswitch vertically off the rod holding it in position.
      • Desolder the wire from the terminal (metal connection point).
      • Beware of overheating the soldering kit as it can damage electronic components.
      • Use a wire stripper or small blade to strip the insulation approximately 1 cm from the end of the wire before resoldering to the new part.
      Ask FixBot
Saul Aguiar
293 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 43
All Time: 621
