Shop the Holiday Gift Guide
Massage Gun Battery Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
64
Past 7 Days:
316
Past 30 Days:
1,362
All Time:
4,663
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your massage gun won't start or quickly stops when you are using it the battery probably needs replacing. The majority of these guns are of a similar design so the replacement method shown here should work with most guns.
    1. Massage Gun Battery Replacement, Gun Dissasembly: step 1, image 1 of 3 Massage Gun Battery Replacement, Gun Dissasembly: step 1, image 2 of 3 Massage Gun Battery Replacement, Gun Dissasembly: step 1, image 3 of 3
      • The rear part of the gun contains the controls.
      • Remove the screw that locks the controls lid to the gun.
      • Twist the lid to release the lid from the gun.
      Ask FixBot
    2. Massage Gun Battery Replacement, Circuit Board Removal: step 2, image 1 of 2 Massage Gun Battery Replacement, Circuit Board Removal: step 2, image 2 of 2
      • One or more sets of wires are usually connected to a circuit board.
      • I placed black marks on the male and female parts to indicate their proper location.
      Ask FixBot
    3. Massage Gun Battery Replacement, Seperating the gun: step 3, image 1 of 2 Massage Gun Battery Replacement, Seperating the gun: step 3, image 2 of 2
      • Remove the screws securing the body of the gun.
      • Separate the halves of the gun body.
      Ask FixBot
    4. Massage Gun Battery Replacement, Motor Removal: step 4, image 1 of 3 Massage Gun Battery Replacement, Motor Removal: step 4, image 2 of 3 Massage Gun Battery Replacement, Motor Removal: step 4, image 3 of 3
      • Remove the bearing screw.
      • Remove the 4 screws that hold the motor to the gun.
      • Remove the motor from the gun.
      Ask FixBot
    5. Massage Gun Battery Replacement, Battery cover: step 5, image 1 of 3 Massage Gun Battery Replacement, Battery cover: step 5, image 2 of 3 Massage Gun Battery Replacement, Battery cover: step 5, image 3 of 3
      • The bottom of the gun has a label that must be removed.
      • Remove the screws to access the battery.
      • The battery cover can now be removed.
      Ask FixBot
    6. Massage Gun Battery Replacement, Battery access: step 6, image 1 of 3 Massage Gun Battery Replacement, Battery access: step 6, image 2 of 3 Massage Gun Battery Replacement, Battery access: step 6, image 3 of 3
      • The battery and a sponge insert can now be removed from the gun.
      • The gun originally contained a Li-ion Battery Pack rated at 7.4 V - 2000mAh-14.8Wh.
      • I replaced it with a 7.4 V 2600mAh-19.24wh Li-ion Battery Pack. The 7.4V is the vital consideration. The other numbers indicate how much current the battery can supply and the total energy the battery can store. These batteries are used for RC cars, boats, toys, etc. and are easily obtained. Mine came from Amazon.
      Ask FixBot
    7. Massage Gun Battery Replacement, Wire Length: step 7, image 1 of 2 Massage Gun Battery Replacement, Wire Length: step 7, image 2 of 2
      • The leads from the old battery were longer than the new battery.
      • Cut the new battery wires and splice a length of the old connector wire to increase the length.
      • Cut one wire at a time. If you cut through both wires simultaneously you will create a short circuit.
      Ask FixBot
    8. Massage Gun Battery Replacement, Splice a Longer Wire: step 8, image 1 of 2 Massage Gun Battery Replacement, Splice a Longer Wire: step 8, image 2 of 2
      • Solder the wires to increase the length.
      • Insulate the spliced wires.
      Ask FixBot
3 other people completed this guide.
Author
with
ralph Kaj
1,103 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 64
Past 7 Days: 316
Past 30 Days: 1,362
All Time: 4,663
