Marshall Uxbridge Power Relay Replacement
    1. Marshall Uxbridge Power Relay Replacement, Back Panel: step 1, image 1 of 3 Marshall Uxbridge Power Relay Replacement, Back Panel: step 1, image 2 of 3 Marshall Uxbridge Power Relay Replacement, Back Panel: step 1, image 3 of 3
      • Orient your speaker so that the back is facing you.
      • Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
      • Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
      Ask FixBot
    2. Marshall Uxbridge Power Relay Replacement: step 2, image 1 of 2 Marshall Uxbridge Power Relay Replacement: step 2, image 2 of 2
      • Detach the white connector from inside the bottom of the back panel.
      • Detach the small red and white connectors from the motherboard on the left side of the back panel.
      Ask FixBot
    3. Marshall Uxbridge Power Relay Replacement: step 3, image 1 of 1
      • Pull the blue ribbon cables from the motherboard.
      • Remove the back panel from the speaker base.
      Ask FixBot
    1. Marshall Uxbridge Power Relay Replacement, Power Relay: step 4, image 1 of 2 Marshall Uxbridge Power Relay Replacement, Power Relay: step 4, image 2 of 2
      • Orient the bottom of the speaker to face away from you.
      • Use a Phillips #1 screwdriver to remove the two 12 mm screws holding the power relay in place.
      Ask FixBot
    2. Marshall Uxbridge Power Relay Replacement: step 5, image 1 of 1
      • Separate the power relay from the speaker.
      • Slide out the blue ribbon cable from the power relay.
      Ask FixBot
    3. Marshall Uxbridge Power Relay Replacement: step 6, image 1 of 2 Marshall Uxbridge Power Relay Replacement: step 6, image 2 of 2
      • Turn the power relay over to the other side.
      • Use a Phillips #000 screwdriver to remove the four 6 mm screws from the power relay.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 49
All Time: 294
