Marshall Major IV hinge replacement
    1. Marshall Major IV hinge replacement, Remove the screw: step 1, image 1 of 2 Marshall Major IV hinge replacement, Remove the screw: step 1, image 2 of 2
      • Use a pointy object like a screwdriver, or your finger if you are handy, to remove the pin.
      Ask FixBot
    2. Marshall Major IV hinge replacement, Align the headphone and its stem and insert the first part of the hinge inside: step 2, image 1 of 2 Marshall Major IV hinge replacement, Align the headphone and its stem and insert the first part of the hinge inside: step 2, image 2 of 2
      • Ensure to align the headphone and its stem and insert the first part of the hinge inside
      Ask FixBot
    3. Marshall Major IV hinge replacement, Insert the hinge cover: step 3, image 1 of 1
      • Using the iFixit opening tool, or any object made to break if you apply pressure that is too high, insert the hinge cover. It is the smaller piece that cover the stem. Do not hesitate to apply force, because everything is very tight.
      Ask FixBot
      • Do this the same way the screw was removed; by applying pressure on the screw.
      Ask FixBot
      • To adjust the stem, you need to apply a lot of force because everything is tight. The friction could make it easier to adjust over time, or it may be easier for you if you use another hinge
      Ask FixBot
Finish Line
3 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Louis Couture
253 Reputation
1 Guide authored
1 Guide Comment
bonjour, ou avez vous acheté la charnière de remplacement svp ?
bienvenu KABA - Reply Share
Past 24 Hours: 9
Past 7 Days: 37
Past 30 Days: 195
All Time: 3,956
