Manual Top-Cut Can Opener Cutting Wheel Replacement
  1. Manual Top-Cut Can Opener Cutting Wheel Replacement, Cutting Wheel: step 1, image 1 of 3 Manual Top-Cut Can Opener Cutting Wheel Replacement, Cutting Wheel: step 1, image 2 of 3 Manual Top-Cut Can Opener Cutting Wheel Replacement, Cutting Wheel: step 1, image 3 of 3
    • Remove the 6 mm Phillips screw that secures the cutting wheel.
  2. Manual Top-Cut Can Opener Cutting Wheel Replacement: step 2, image 1 of 2 Manual Top-Cut Can Opener Cutting Wheel Replacement: step 2, image 2 of 2
    • Detach the cutting wheel and gear. Place them aside.
  3. Manual Top-Cut Can Opener Cutting Wheel Replacement: step 3, image 1 of 1
    • Liberally spray the WD-40 onto the rusty areas of the shaft.
    • WD-40 is an extremely flammable aerosol. Avoid spraying it near flames, heat, or hot surfaces.
  4. Manual Top-Cut Can Opener Cutting Wheel Replacement: step 4, image 1 of 2 Manual Top-Cut Can Opener Cutting Wheel Replacement: step 4, image 2 of 2
    • Scrub the WD-40 and any rust off the can opener using a scouring pad.
    • Wipe away any excess WD-40 with a paper towel.
  5. Manual Top-Cut Can Opener Cutting Wheel Replacement: step 5, image 1 of 3 Manual Top-Cut Can Opener Cutting Wheel Replacement: step 5, image 2 of 3 Manual Top-Cut Can Opener Cutting Wheel Replacement: step 5, image 3 of 3
    • Reassemble the can opener by reversing steps 1 and 2 with a new wheel:
    • Place the gear and new cutting wheel onto the shaft.
    • Reinsert the 6 mm Phillips screw and fasten it in place.
Once reassembly is complete, your can opener will be as good as new!
Hannah Freitas
133 Reputation
1 Guide authored
UC Davis, Team 3-2, Whithaus Spring 2025 Member of UC Davis, Team 3-2, Whithaus Spring 2025
UCD-WHITHAUS-S25S3G2
3 Members
1 Guide authored
1 Guide Comment
Onde acho uma nova roda ou novo disco para comprar?
NEWTON SANTOS PEREIRA - Reply
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 83
All Time: 478
