Makita XPH01 LED Light Replacement
  1. Makita XPH01 LED Light Replacement, Battery: step 1, image 1 of 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 LED Light Replacement: step 2, image 1 of 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 LED Light Replacement: step 3, image 1 of 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 LED Light Replacement, Outer Casing: step 4, image 1 of 2 Makita XPH01 LED Light Replacement, Outer Casing: step 4, image 2 of 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 LED Light Replacement: step 5, image 1 of 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 LED Light Replacement: step 6, image 1 of 2 Makita XPH01 LED Light Replacement: step 6, image 2 of 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 LED Light Replacement: step 7, image 1 of 2 Makita XPH01 LED Light Replacement: step 7, image 2 of 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 LED Light Replacement, LED Light: step 8, image 1 of 2 Makita XPH01 LED Light Replacement, LED Light: step 8, image 2 of 2
    • Use the pointed end of a plastic spudger to push the LED out of the drill.
  9. Makita XPH01 LED Light Replacement: step 9, image 1 of 2 Makita XPH01 LED Light Replacement: step 9, image 2 of 2
    • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
    • Use the pointed edge of a spudger to pull out the plastic connector.
  10. Makita XPH01 LED Light Replacement: step 10, image 1 of 3 Makita XPH01 LED Light Replacement: step 10, image 2 of 3 Makita XPH01 LED Light Replacement: step 10, image 3 of 3
    • Use the flat end of the spudger to push in the clip on the plastic connector.
    • Pull both sides of the plastic connector apart.
  11. Makita XPH01 LED Light Replacement: step 11, image 1 of 3 Makita XPH01 LED Light Replacement: step 11, image 2 of 3 Makita XPH01 LED Light Replacement: step 11, image 3 of 3
    • Pull the silver metal clip on the motor away from the drill.
  12. Makita XPH01 LED Light Replacement: step 12, image 1 of 1
    • Pull the black trigger assembly away from the drill.
  13. Makita XPH01 LED Light Replacement: step 13, image 1 of 2 Makita XPH01 LED Light Replacement: step 13, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to pull out the LED light assembly.
    very nice tutorial !
    King Rump - Reply
2 other people completed this guide.
Eric Herwatt
984 Reputation
7 Guides authored
Cal Poly, Team 15-4, Livingston Fall 2016 Member of Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Members
7 Guides authored
One Comment
Should I do these steps if my drill is under a warranty?
Richard Williams - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 41
All Time: 2,473
