Making a low cost photography light stand
    1. Making a low cost photography light stand, Unplug the lamp: step 1, image 1 of 1
      • Before disassembling on the lamp, it MUST be unplugged!
      Ask FixBot
    2. Making a low cost photography light stand, Remove the lightbulb: step 2, image 1 of 3 Making a low cost photography light stand, Remove the lightbulb: step 2, image 2 of 3 Making a low cost photography light stand, Remove the lightbulb: step 2, image 3 of 3
      • If the bulb is worth keeping, this can be reused.
      • If the lamp has a lightbulb installed, remove it from the lamp.
      Ask FixBot
    3. Making a low cost photography light stand, Remove the socket cover: step 3, image 1 of 3 Making a low cost photography light stand, Remove the socket cover: step 3, image 2 of 3 Making a low cost photography light stand, Remove the socket cover: step 3, image 3 of 3
      • MOST LAMPS WILL BE SIMILAR, but designs can vary.
      • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
      • Remove the socket cover. Once removed, remove the bulb socket.
      Ask FixBot
    4. Making a low cost photography light stand, Remove the bulb socket: step 4, image 1 of 2 Making a low cost photography light stand, Remove the bulb socket: step 4, image 2 of 2
      • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
      • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
      • Discard any broken or unwanted components.
      Ask FixBot
    5. Making a low cost photography light stand, Remove the cord: step 5, image 1 of 3 Making a low cost photography light stand, Remove the cord: step 5, image 2 of 3 Making a low cost photography light stand, Remove the cord: step 5, image 3 of 3
      • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
      • After removing the bulb socket, remove the power cord.
      Ask FixBot
    6. Making a low cost photography light stand, Test the lamp and find a good clamp point: step 6, image 1 of 1
      • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
      Ask FixBot
Finish Line
2 other people completed this guide.
Nick
106,347 Reputation
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 121
All Time: 1,476
