You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide will walk you through the process of replacing the front axle in a Maisto Rock Crawler.
  1. Flip the R/C truck over. To take off the R/C truck top, use the driver and bit PH2 and remove the four  7.7mm Philips screws highlighted.
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
  2. Half way remove the truck top so you can unhinge the antenna from the clips. Remove the R/C truck top completely.
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
  4. After removing the plate use the driver and bit J1 to unscrew the two 9.5 mm Philips screws that hold the side circuit board in.
    • After removing the plate use the driver and bit J1 to unscrew the two 9.5 mm Philips screws that hold the side circuit board in.
  5. Flip the R/C truck over and remove the four 10 mm bottom under-body plate screws using the driver and bit PH2.
    • Flip the R/C truck over and remove the four 10 mm bottom under-body plate screws using the driver and bit PH2.
  6. Flip the R/C truck back over.
    • Flip the R/C truck back over.
    • Remember which wire is connected at which pin before desoldering.
    • Desolder the 4 wires connected from the front axle to the circuit board.
  7. You can refer to the tire replacement guide to keep salvageable tires from the removed axle.
    • You can refer to the tire replacement guide to keep salvageable tires from the removed axle.
kevin
787 Reputation
6 Guides authored
USF Tampa, Team 1-2, Sullivan Spring 2016 Member of USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
3 Members
6 Guides authored
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 36
All Time: 3,655
