Maginon BIK-3 Wireless Stereo Earphone Assembly Replacement
  1. Maginon BIK-3 Wireless Stereo Earphone Assembly Replacement, 6 individual parts after fall: step 1, image 1 of 2 Maginon BIK-3 Wireless Stereo Earphone Assembly Replacement, 6 individual parts after fall: step 1, image 2 of 2
    • Sort the parts and take the small metal spring
    • Use the ifixit reverse tweezers
  2. Maginon BIK-3 Wireless Stereo Earphone Assembly Replacement, Guide metal spring into the lid: step 2, image 1 of 2 Maginon BIK-3 Wireless Stereo Earphone Assembly Replacement, Guide metal spring into the lid: step 2, image 2 of 2
    • Push the metal spring through the opening into the cover
    • Connect the lid with the spring to the cover
  3. Maginon BIK-3 Wireless Stereo Earphone Assembly Replacement, Assembling the cover with the electronic: step 3, image 1 of 2 Maginon BIK-3 Wireless Stereo Earphone Assembly Replacement, Assembling the cover with the electronic: step 3, image 2 of 2
    • Carefully slide the electronics block together with the cover and lid, but make sure it is on the correct side (see the recess at the bottom for the charger). When everything is in place, press lightly until it clicks into place.
  4. Maginon BIK-3 Wireless Stereo Earphone Assembly Replacement, Device check: step 4, image 1 of 1
    • If the control light in the lid and on the bottom side is on, you got it !!!!
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Isabel Suchanek
205 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 246
