Magic Circle Crochet Repair
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
61
All Time:
272
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Many crochet projects begin with an adjustable starting loop called a magic circle that is secured by just one main section of yarn at the center. The adjustable loop and center stitches will open/unravel if that section of yarn is cut or damaged. This guide describes the process of repairing crochet projects with damage to the center of their magic circle.
Tools
    1. Magic Circle Crochet Repair, Magic Circle Crochet Repair: step 1, image 1 of 1
      • Locate the loose section of yarn at the center of your project's magic circle. This will be your starting point for the repair.
      • Using your scissors and additional yarn, cut a section of yarn that is about 5-10 inches long. This will be your repair yarn.
      • Tie the two ends together.
      • It is best if you use the same yarn from your original project, or yarn that is similar in weight and color, because the repair yarn will then blend with the project more seamlessly. This guide uses black yarn so that each step is easier to see.
      Ask FixBot
    2. Magic Circle Crochet Repair: step 2, image 1 of 3 Magic Circle Crochet Repair: step 2, image 2 of 3 Magic Circle Crochet Repair: step 2, image 3 of 3
      • Hide the excess yarn by threading your tapestry needle with the shorter end of the repair yarn and the starting section of yarn. Weave these ends into nearby stitches with your tapestry needle. Leave the long end of your repair yarn out.
      Ask FixBot
    3. Magic Circle Crochet Repair: step 3, image 1 of 3 Magic Circle Crochet Repair: step 3, image 2 of 3 Magic Circle Crochet Repair: step 3, image 3 of 3
      • The bottom of each stitch is made up of two loops of yarn. Thread the longer piece of your repair yarn through the tapestry needle and send them through both bottom loops of the nearest center stitch.
      • Continue to weave the repair yarn through the bottom loops of each remaining center stitch with your tapestry needle.
      Ask FixBot
    4. Magic Circle Crochet Repair: step 4, image 1 of 2 Magic Circle Crochet Repair: step 4, image 2 of 2
      • Weave the tapestry needle through your first stitch again and pull the repair yarn tight to bring the re-threaded center stitches together. This will close the center of your magic circle.
      Ask FixBot
    5. Magic Circle Crochet Repair: step 5, image 1 of 3 Magic Circle Crochet Repair: step 5, image 2 of 3 Magic Circle Crochet Repair: step 5, image 3 of 3
      • Weave the tapestry needle through the ending stitch once more, but do not pull the repair yarn the way through. This leaves a loop of repair yarn.
      • Send the tapestry needle through the center of your repair yarn loop and tighten to secure the repair yarn. This knot ensures that your magic circle stays closed.
      Ask FixBot
    6. Magic Circle Crochet Repair: step 6, image 1 of 3 Magic Circle Crochet Repair: step 6, image 2 of 3 Magic Circle Crochet Repair: step 6, image 3 of 3
      • Weave the repair yarn through all of the center stitches once more for added stability and to begin hiding the excess repair yarn.
      • Weave the tapestry needle through the center of your nearest second-row stitch in the project and pull the repair yarn through.
      • Optionally, you can continue to weave the repair yarn through additional stitches in your piece. This further stabilizes the magic circle's repaired center by giving the repair yarn more resistance to movement and pulling.
      Ask FixBot
    7. Magic Circle Crochet Repair: step 7, image 1 of 2 Magic Circle Crochet Repair: step 7, image 2 of 2
      • Use your scissors to trim any excess repair yarn after the magic circle is secured. Check for any loose ends on the front and back of your piece once the repair is completed, and hide them by weaving in or trimming with scissors as necessary.
      Ask FixBot
Once the magic circle is repaired, use or wear your project as originally intended. If the center yarn is damaged again, just perform the steps of this guide again!
Kaytlin Gross
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 61
All Time: 272
