Magic Bullet NutriBullet Power Cord Replacement
  1. Magic Bullet NutriBullet Power Cord Replacement, Power Cord: step 1, image 1 of 2 Magic Bullet NutriBullet Power Cord Replacement, Power Cord: step 1, image 2 of 2
    • Before beginning, make sure the device is unplugged.
    • With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
  2. Magic Bullet NutriBullet Power Cord Replacement: step 2, image 1 of 1
    • Once the screws are removed, pull the plastic base up gently.
    • Once the plastic base is removed, there is a fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  3. Magic Bullet NutriBullet Power Cord Replacement: step 3, image 1 of 1
    • Gently lift the power cord from its side slot and place it to the side.
  4. Magic Bullet NutriBullet Power Cord Replacement: step 4, image 1 of 2 Magic Bullet NutriBullet Power Cord Replacement: step 4, image 2 of 2
    • With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket.
    • The white safety bracket holds the cord down. After removing it, the chord will be free.
  5. Magic Bullet NutriBullet Power Cord Replacement: step 5, image 1 of 1
    • After removing the gray base and silver casing, the wires will now be free and you will have easy access to them.
    • Gently pull out the two plastic covers at the end of the wires.
  6. Magic Bullet NutriBullet Power Cord Replacement: step 6, image 1 of 1
    • Use tape or clamps to hold the wires together for an easy soldering experience.
    • Using a soldering iron, solder your new wire to the red wire.
Geary Yu
1,217 Reputation
3 Guides authored
Cal Poly, Team 19-8, Maness Winter 2015 Member of Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 63
All Time: 15,009
