Macs wireless keyboard for PS4 controller Disassembly
    1. Macs wireless keyboard for PS4 controller Disassembly, Macs wireless keyboard for PS4 controller Disassembly: step 1, image 1 of 2 Macs wireless keyboard for PS4 controller Disassembly, Macs wireless keyboard for PS4 controller Disassembly: step 1, image 2 of 2
      • Turn keyboard upside down.
      • Unscrew all the four 7 mm Phillips J1 screws on the bottom.
      Ask FixBot
    2. Macs wireless keyboard for PS4 controller Disassembly: step 2, image 1 of 2 Macs wireless keyboard for PS4 controller Disassembly: step 2, image 2 of 2
      • Slide an opening pick between the upper and lower part of the frame from the corner of the keyboard.
      • Slide the pick all the way around the keyboard.
      • As the frames seperate, it is recommended to keep the controller upside down, to prevent the insides accidentally falling out and potentially damaging the keyboard.
      Ask FixBot
    3. Macs wireless keyboard for PS4 controller Disassembly: step 3, image 1 of 2 Macs wireless keyboard for PS4 controller Disassembly: step 3, image 2 of 2
      • Carefully remove the button caps.
      Ask FixBot
    4. Macs wireless keyboard for PS4 controller Disassembly: step 4, image 1 of 1
      • Move the battery out of the way.
      • The battery has been secured with adhesive tape, so slight force may have to be used.
      • Be careful not to pull too much on the battery, as the batterys cables are soldered on the board, and the solder may come off if pulled too much.
      Ask FixBot
    5. Macs wireless keyboard for PS4 controller Disassembly: step 5, image 1 of 1
      • Move the 3,5 mm jack connector out of the way.
      • Use the same caution as for the battery cables. The jack cables are soldered on the board the same way as the battery cables are.
      Ask FixBot
    6. Macs wireless keyboard for PS4 controller Disassembly: step 6, image 1 of 2 Macs wireless keyboard for PS4 controller Disassembly: step 6, image 2 of 2
      • Unscrew the last four 5 mm screws from the frame, with a Phillips #000 size bit.
      Ask FixBot
    7. Macs wireless keyboard for PS4 controller Disassembly: step 7, image 1 of 2 Macs wireless keyboard for PS4 controller Disassembly: step 7, image 2 of 2
      • Flip the keyboard around, and slide an opening pick between the frame and the actual keyboard.
      • Slide the pick alongside the edge of the frame.
      Ask FixBot
    8. Macs wireless keyboard for PS4 controller Disassembly: step 8, image 1 of 2 Macs wireless keyboard for PS4 controller Disassembly: step 8, image 2 of 2
      • The keyboard buttons come off just by lifting.
      Ask FixBot
    9. Macs wireless keyboard for PS4 controller Disassembly: step 9, image 1 of 2 Macs wireless keyboard for PS4 controller Disassembly: step 9, image 2 of 2
      • The motherboard comes off by lifting it from it's socket.
      • The motherboard cannot be completely pulled out unless the component from the lower frame part is soldered off.
      Ask FixBot
To reassemble the keyboard, follow these instructions in reverse order.
HoPo-_
726 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 59
All Time: 399
