Macintosh Powerbook 5300cs Battery Replacement
  1. Macintosh Powerbook 5300cs Battery Replacement, Battery: step 1, image 1 of 1
    • The battery compartment is located in the front-right side of the laptop. The battery should be located inside this compartment.
  2. Macintosh Powerbook 5300cs Battery Replacement: step 2, image 1 of 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
noah fischer
222 Reputation
1 Guide authored
Cal Poly, Team 6-1, Regan Fall 2011 Member of Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,545
