Repairing Macintosh PowerBook 1400 Series RAM
  1. Repairing Macintosh PowerBook 1400 Series RAM, Battery: step 1, image 1 of 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Repairing Macintosh PowerBook 1400 Series RAM: step 2, image 1 of 1
    • Slide the latch to the left to release the battery.
  3. Repairing Macintosh PowerBook 1400 Series RAM: step 3, image 1 of 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Repairing Macintosh PowerBook 1400 Series RAM, CD-ROM Drive: step 4, image 1 of 1
    • Locate the CD-ROM Drive latch.
  5. Repairing Macintosh PowerBook 1400 Series RAM: step 5, image 1 of 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Repairing Macintosh PowerBook 1400 Series RAM: step 6, image 1 of 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Repairing Macintosh PowerBook 1400 Series RAM, Keyboard: step 7, image 1 of 1
    • Locate the speaker cover.
  8. Repairing Macintosh PowerBook 1400 Series RAM: step 8, image 1 of 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Repairing Macintosh PowerBook 1400 Series RAM: step 9, image 1 of 1
    • Gently lift the speaker cover to remove it.
  10. Repairing Macintosh PowerBook 1400 Series RAM: step 10, image 1 of 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Repairing Macintosh PowerBook 1400 Series RAM: step 11, image 1 of 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Repairing Macintosh PowerBook 1400 Series RAM: step 12, image 1 of 1
    • Tilt the keyboard away from the screen.
  13. Repairing Macintosh PowerBook 1400 Series RAM: step 13, image 1 of 1
    • Locate the six screws that secure the heatsink.
  14. Repairing Macintosh PowerBook 1400 Series RAM: step 14, image 1 of 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Repairing Macintosh PowerBook 1400 Series RAM: step 15, image 1 of 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Repairing Macintosh PowerBook 1400 Series RAM: step 16, image 1 of 1
    • Remove the heatsink.
  17. Repairing Macintosh PowerBook 1400 Series RAM: step 17, image 1 of 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Repairing Macintosh PowerBook 1400 Series RAM: step 18, image 1 of 1
    • Detach the ribbon cable.
  19. Repairing Macintosh PowerBook 1400 Series RAM: step 19, image 1 of 1
    • Remove the keyboard.
  20. Repairing Macintosh PowerBook 1400 Series RAM, Memory (RAM): step 20, image 1 of 1
    • Identify RAM Memory stick
    • These are the upgradeable RAM Memory sticks, they must be removed first
  21. Repairing Macintosh PowerBook 1400 Series RAM: step 21, image 1 of 1
    • Gently grasp the ram on the far end as shown in the picture and then pull up and away from the right side of the computer
  22. Repairing Macintosh PowerBook 1400 Series RAM: step 22, image 1 of 1
    • Remove the upgradeable RAM stick
    • If the upgradeable RAM stick is all you are repairing you can end the guide here, however to remove the factory installed RAM please continue
  23. Repairing Macintosh PowerBook 1400 Series RAM: step 23, image 1 of 1
    • Gently grasp the factory installed RAM by grabbing each end as shown in the picture and pull the stick directly up
  24. Repairing Macintosh PowerBook 1400 Series RAM: step 24, image 1 of 1
    • Remove the factory installed RAM memory module
Kian Dinyari
146 Reputation
1 Guide authored
Cal Poly, Team 10-39, Forte Spring 2011 Member of Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 27
All Time: 4,186
