15% Off Selected iFixit Tools — Limited Time
Unibody MacBook Pro 15" Glass Replacement
  1. Unibody MacBook Pro 15" Glass Replacement, Prepare a Workspace: step 1, image 1 of 1
    • Set up a clean workspace and gather all supplies. You will need your Macbook Pro, a new screen, a hair dryer, a screen cleaning cloth, and a suction cup.
    Ask FixBot
  2. Unibody MacBook Pro 15" Glass Replacement, Heat the Edges of the Screen: step 2, image 1 of 2 Unibody MacBook Pro 15" Glass Replacement, Heat the Edges of the Screen: step 2, image 2 of 2
    • Use a hair dryer to heat the adhesive around the edges of the screen you are removing.
    Ask FixBot
  3. Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: step 3, image 1 of 3 Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: step 3, image 2 of 3 Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: step 3, image 3 of 3
    • Attach the suction cup found in the iFixit repair kit to the corner of your screen, by gently pressing down until it seals. Lift screen away by pulling up on the suction cup key ring.
    Ask FixBot
  4. Unibody MacBook Pro 15" Glass Replacement, Preparing for the New Screen: step 4, image 1 of 2 Unibody MacBook Pro 15" Glass Replacement, Preparing for the New Screen: step 4, image 2 of 2
    • Use a screen cleaning cloth to buff out any marks on your Macbook Pros screen surface.
    • Use a screen cleaning cloth to buff out any marks on the inside of new glass that will be applied.
    Ask FixBot
  5. Unibody MacBook Pro 15" Glass Replacement, Preparing Screen Adhesive: step 5, image 1 of 2 Unibody MacBook Pro 15" Glass Replacement, Preparing Screen Adhesive: step 5, image 2 of 2
    • Remove the strips covering the adhesive on the new screen.
    • Heat the new adhesive strips evenly using the hair dryer.
    Ask FixBot
  6. Unibody MacBook Pro 15" Glass Replacement, Applying the New Screen: step 6, image 1 of 2 Unibody MacBook Pro 15" Glass Replacement, Applying the New Screen: step 6, image 2 of 2
    • Place the new screen in position. Confirm that the new screen is properly aligned with the edges of the Macbook Pro.
    Ask FixBot
  7. Unibody MacBook Pro 15" Glass Replacement, Attaching the New Screen: step 7, image 1 of 2 Unibody MacBook Pro 15" Glass Replacement, Attaching the New Screen: step 7, image 2 of 2
    • Using the screen cleaning cloth carefully press the edges of the screen to seal the adhesive.
    Ask FixBot
  8. Unibody MacBook Pro 15" Glass Replacement, Remove Cover: step 8, image 1 of 1
    • Peel the protective covering off the new screen.
    Ask FixBot
  9. Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: step 9, image 1 of 3 Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: step 9, image 2 of 3 Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: step 9, image 3 of 3
    • To insure the seal of the adhesive, reheat it again with the hair drying.
    Ask FixBot
  10. Unibody MacBook Pro 15" Glass Replacement, Final Press: step 10, image 1 of 1
    • Finally, use the screen cleaning cloth and carefully press the edges of the screen one more time.
    Ask FixBot
  11. Unibody MacBook Pro 15" Glass Replacement, You did it!: step 11, image 1 of 1
    • Enjoy your laptop with it's brand new Glass!
    Ask FixBot
This guide provides all instructions necessary to dismantle and replace a Macbook Pro Screen.
44 other people completed this guide.
Akh1913
1,345 Reputation
1 Guide authored
PIRL Gadget Garage Member of PIRL Gadget Garage
Community
9 Members
10 Guides authored
20 Guide Comments
How did you know the correct part number for your specific MacBook? Where did you source the glass?
frightanic.com - Reply Share
I sourced my glass this eBay seller: http://www.ebay.com/usr/beetstech?_trksi...
To find the correct part, I followed iFixit's "ID your Mac" prompts in the parts store, then selected the glass panel from the list of compatible parts.
Hope this helps!
Noah Smith - Reply Share
Is it useful for internal crack
tiffanyts - Reply Share
FYI, OWC (Other World Computing, aka macsales.com) has the 15-inch glass for $25, and the 13-inch for $24:
https://eshop.macsales.com/item/Apple/MB... (15-inch)
https://eshop.macsales.com/item/Apple/MB... (13-inch)
…and I just discovered they even have the 17-inch:
One last comment: get the glass as hot as you can!
jiclark - Reply Share
Does this work for the Late-2013 Retina MacBook Pro (15-inch)?
Brian Shiau - Reply Share
Past 24 Hours: 8
Past 7 Days: 26
Past 30 Days: 186
All Time: 137,982
