Installing MacBook Unibody Model A1342 LCD
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Unibody Model A1342 LCD, LCD: step 1, image 1 of 1
    • Remove following six screws securing the LCD to the rear display bezel:
    • Four 3.4 mm Phillips.
    • Two 3 mm Phillips.
  2. Installing MacBook Unibody Model A1342 LCD: step 2, image 1 of 1
    • Do not try to remove the LCD yet. The circuitry along its lower edge is wedged in a gap along the lower edge of the display recess in the plastic display assembly.
    • Hold the display vertically and tip it enough to grab the top edge of the LCD and rotate it slightly out of the display assembly, being careful not to break the circuitry off its lower edge.
  3. Installing MacBook Unibody Model A1342 LCD: step 3, image 1 of 1
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  4. Installing MacBook Unibody Model A1342 LCD: step 4, image 1 of 2 Installing MacBook Unibody Model A1342 LCD: step 4, image 2 of 2
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 802
