Introduction
Use this guide to replace a broken trackpad.
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Remove the two 5 mm Phillips screws securing the keyboard flex bracket to the upper case.
Lift the keyboard flex bracket out of the upper case.
Carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
De-route the trackpad cable through its slot cut into the upper case.
Pull the trackpad away from the outer edge of the upper case.
Remove the old trackpad and set it aside.
Carefully insert the cable from your new trackpad through its slot cut into the upper case.
Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
Pull the trackpad cable as you seat the trackpad into its void in the upper case.
Insert a 1.4 mm Tri-point screw into each of the outer holes drilled into the trackpad (two screws total).
While continually trying to click your trackpad, gently tighten the Tri-point set screw until the clicks return to their factory "feel".
Next, flip your upper case over so the keyboard side is facing up.
Align the trackpad so it is centered in its hole cut into the upper case.
Tighten the outer two screws along the inner edge of the trackpad and check the alignment of it on the outer side of the upper case.
If its alignment looks good, install the rest of the Tri-point screws along the inner edge of the trackpad.
Before reassembling your machine, verify that the set screw is still installed in a position so the mouse will click correctly.
