MacBook Unibody Model A1278 Hard Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Unibody Model A1278 Hard Drive Replacement, Access Door: step 1, image 1 of 1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 Hard Drive Replacement: step 2, image 1 of 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 Hard Drive Replacement, Battery: step 3, image 1 of 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. MacBook Unibody Model A1278 Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the single Phillips screw securing the hard drive bracket to the upper case.
    • This screw is captive to the hard drive bracket.
  5. MacBook Unibody Model A1278 Hard Drive Replacement: step 5, image 1 of 1
    • Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
    • Lift the hard drive out of the chassis, minding the cable attaching it to the computer.
  6. MacBook Unibody Model A1278 Hard Drive Replacement: step 6, image 1 of 1
    • Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
    • Hard drive remains.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,545
