Introduction
This is a prerequisite guide describing how to replace MacBook Pro Retina feet, applicable to models A1425, A1502, and A1398. For a full guide including lower case removal, refer to the specific MacBook Pro device pages.
Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
Remove any broken or damaged feet.
If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
Align the new foot inside the cavity.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
Repeat the last seven steps for any remaining broken or worn feet.
