MacBook Pro 17" Unibody RAM Replacement
  1. MacBook Pro 17" Unibody RAM Replacement, Lower Case: step 1, image 1 of 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody RAM Replacement: step 2, image 1 of 2 MacBook Pro 17" Unibody RAM Replacement: step 2, image 2 of 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody RAM Replacement, Battery: step 3, image 1 of 3 MacBook Pro 17" Unibody RAM Replacement, Battery: step 3, image 2 of 3 MacBook Pro 17" Unibody RAM Replacement, Battery: step 3, image 3 of 3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody RAM Replacement, RAM: step 4, image 1 of 3 MacBook Pro 17" Unibody RAM Replacement, RAM: step 4, image 2 of 3 MacBook Pro 17" Unibody RAM Replacement, RAM: step 4, image 3 of 3
    • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 118
All Time: 96,509
