Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive, Battery: step 1, image 1 of 1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  2. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive, RAM Shield: step 2, image 1 of 1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 3, image 1 of 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive, Upper Case: step 4, image 1 of 1
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  5. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 5, image 1 of 1
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
  6. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 6, image 1 of 1
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
  7. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 7, image 1 of 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 8, image 1 of 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 9, image 1 of 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  10. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 10, image 1 of 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
  11. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive, Optical Drive: step 11, image 1 of 1
    • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  12. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 12, image 1 of 1
    • Remove the following three screws:
    • Two black T6 Torx screws on either side of the SuperDrive.
    • One longer silver T6 Torx screw at the back of the drive near the speaker.
  13. Installing MacBook Pro 17" Models A1151 A1212 and A1229 Optical Drive: step 13, image 1 of 1
    • Use one hand to pull back the speaker cable and use your other hand to lift the optical drive up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 7,480
