Installing MacBook Pro 15" Unibody Mid 2010 Right Fan
  1. Installing MacBook Pro 15" Unibody Mid 2010 Right Fan, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. Installing MacBook Pro 15" Unibody Mid 2010 Right Fan: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. Installing MacBook Pro 15" Unibody Mid 2010 Right Fan, Right Fan: step 3, image 1 of 1
    • Remove three T6 Torx screws securing the right fan to the logic board and upper case.
  4. Installing MacBook Pro 15" Unibody Mid 2010 Right Fan: step 4, image 1 of 1
    • Use a spudger to pry the fan connector straight up off the logic board.
    • Pry up from beneath the wires.
  5. Installing MacBook Pro 15" Unibody Mid 2010 Right Fan: step 5, image 1 of 1
    • Lift the right fan out of the upper case.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 31,159
