MacBook Pro 15" Unibody Mid 2010 RAM Replacement
  1. MacBook Pro 15" Unibody Mid 2010 RAM Replacement, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 RAM Replacement: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2010 RAM Replacement, RAM: step 3, image 1 of 3 MacBook Pro 15" Unibody Mid 2010 RAM Replacement, RAM: step 3, image 2 of 3 MacBook Pro 15" Unibody Mid 2010 RAM Replacement, RAM: step 3, image 3 of 3
    • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Past 24 Hours: 10
Past 7 Days: 23
Past 30 Days: 106
All Time: 147,278
