Introduction
Wireless connectivity issues? Use this guide to replace an inoperative AirPort/Bluetooth board.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Carefully peel the AirPort/Bluetooth ribbon cable off the top of the black plastic AirPort/Bluetooth housing.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off its socket on the AirPort/Bluetooth board.
Disconnect the camera cable by pulling its connector away from the socket on the logic board.
Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth board.
De-route all three antenna cables from their channels in the black plastic AirPort/Bluetooth housing.
Remove the two Phillips screws securing the AirPort/Bluetooth board housing to the upper case.
Carefully remove the AirPort/Bluetooth assembly from the lower case.
Remove the two Phillips screws securing the AirPort/Bluetooth board to the AirPort/Bluetooth board housing.
