MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
    • Lift the the retaining bracket out of the upper case.
  2. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: step 2, image 1 of 1
    • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
  3. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: step 3, image 1 of 2 MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: step 3, image 2 of 2
    • Remove the hard drive cable by pulling the hard drive straight away from the connector. Keep the connector steady. If pulled by the connector, it can be pulled too far and accidentally tear the hard drive cable.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 664
