Introduction
This guide will show you how to replace the SuperDrive from your laptop (requires a SATA SuperDrive).
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Disconnect the camera cable by pulling the male end straight away from its socket.
Remove two 8 mm Phillips screws securing the camera cable bracket to the upper case.
Lift the camera cable bracket out from the upper case.
Remove the following three Phillips screws securing the optical drive to the upper case:
One 3.5 mm Phillips screw.
Two 2.5 mm Phillips screws.
Remove the optical drive cable by pulling it straight away from the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
