MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement: step 2, image 1 of 1
    • Deroute the camera data cable from the channel in the optical drive.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement: step 3, image 1 of 1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement: step 4, image 1 of 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement: step 4, image 2 of 2
    • Remove two 8 mm Phillips screws securing the camera cable bracket to the upper case.
    • The rightmost screw may remain captive in the camera cable.
    • Lift the camera cable bracket out from the upper case.
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement: step 5, image 1 of 1
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 3.5 mm Phillips screw.
    • Two 2.5 mm Phillips screws.
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement: step 6, image 1 of 1
    • Lift the optical drive from its left edge and pull it out of the computer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,254
