Installing MacBook Pro 15" Unibody Hard Drive Cable
  1. Installing MacBook Pro 15" Unibody Hard Drive Cable, Access Door: step 1, image 1 of 2 Installing MacBook Pro 15" Unibody Hard Drive Cable, Access Door: step 1, image 2 of 2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 2, image 1 of 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. Installing MacBook Pro 15" Unibody Hard Drive Cable, Battery: step 3, image 1 of 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
  4. Installing MacBook Pro 15" Unibody Hard Drive Cable, Lower Case: step 4, image 1 of 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
  5. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 5, image 1 of 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. Installing MacBook Pro 15" Unibody Hard Drive Cable, Optical Drive: step 6, image 1 of 1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
  7. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 7, image 1 of 1
    • Deroute the camera data cable from the channel in the optical drive.
  8. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 8, image 1 of 1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  9. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 9, image 1 of 2 Installing MacBook Pro 15" Unibody Hard Drive Cable: step 9, image 2 of 2
    • Remove two 8 mm Phillips screws securing the camera cable bracket to the upper case.
    • The rightmost screw may remain captive in the camera cable.
    • Lift the camera cable bracket out from the upper case.
  10. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 10, image 1 of 1
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 3.5 mm Phillips screw.
    • Two 2.5 mm Phillips screws.
  11. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 11, image 1 of 1
    • Lift the optical drive from its left edge and pull it out of the computer.
  12. Installing MacBook Pro 15" Unibody Hard Drive Cable, Subwoofer & Right Speaker: step 12, image 1 of 1
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  13. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 13, image 1 of 1
    • Remove the following four screws securing the subwoofer and right speaker to the upper case:
    • Two 3.2 mm Phillips screws.
    • One 2.6 mm Phillips screw.
    • One 5 mm Phillips screw.
  14. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 14, image 1 of 1
    • Lift the subwoofer and right speaker assembly out of the upper case.
  15. Installing MacBook Pro 15" Unibody Hard Drive Cable, Hard Drive Cable: step 15, image 1 of 1
    • Remove the single Phillips screw securing the hard drive bracket to the upper case.
    • This screw is captive in the hard drive bracket.
  16. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 16, image 1 of 1
    • Lift the hard drive by its plastic pull tab and remove the freed hard drive bracket.
  17. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 17, image 1 of 1
    • Lift the hard drive out of its supports and disconnect the SATA cable by pulling the connector straight away from the hard drive.
  18. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 18, image 1 of 1
    • Remove the following 5 screws securing the mid wall to the upper case:
    • Three 10.5 mm Phillips screws.
    • Two 3.7 mm Phillips screws.
    • Lift the mid wall out of the upper case.
  19. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 19, image 1 of 1
  20. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 20, image 1 of 1
    • Use a spudger to pry the hard drive cable connector straight up off the logic board.
  21. Installing MacBook Pro 15" Unibody Hard Drive Cable: step 21, image 1 of 2 Installing MacBook Pro 15" Unibody Hard Drive Cable: step 21, image 2 of 2
    • Peel the hard drive cable from the adhesive securing it to the upper case, and maneuver the plastic retaining block out of the upper case.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 24,044
