MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Disconnect the camera cable connector from its socket on the logic board.
    • Do not lift up on the cable as you disconnect it from the logic board. Pull the cable parallel to the face of the logic board.
  2. MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement: step 2, image 1 of 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
  3. MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement: step 3, image 1 of 1
    • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
  4. MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement: step 4, image 1 of 2 MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement: step 4, image 2 of 2
    • Remove following two screws:
    • Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments on the right before proceeding.
    • One 8.6 mm Phillips screw
    • One 3.9 mm Phillips screw
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
  5. MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement: step 5, image 1 of 1
    • Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
  6. MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement: step 6, image 1 of 1
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,265
