Installing MacBook Pro 15" Unibody Early 2011 Left Fan
  1. Installing MacBook Pro 15" Unibody Early 2011 Left Fan, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. Installing MacBook Pro 15" Unibody Early 2011 Left Fan: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. Installing MacBook Pro 15" Unibody Early 2011 Left Fan, Battery Connector: step 3, image 1 of 2 Installing MacBook Pro 15" Unibody Early 2011 Left Fan, Battery Connector: step 3, image 2 of 2
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. Installing MacBook Pro 15" Unibody Early 2011 Left Fan: step 4, image 1 of 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. Installing MacBook Pro 15" Unibody Early 2011 Left Fan, Left Fan: step 5, image 1 of 1
    • Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
    • In some models, these T6 Torx screws may be 3.1 mm long.
  6. Installing MacBook Pro 15" Unibody Early 2011 Left Fan: step 6, image 1 of 3 Installing MacBook Pro 15" Unibody Early 2011 Left Fan: step 6, image 2 of 3 Installing MacBook Pro 15" Unibody Early 2011 Left Fan: step 6, image 3 of 3
    • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  7. Installing MacBook Pro 15" Unibody Early 2011 Left Fan: step 7, image 1 of 1
    • Lift the left fan out of the upper case.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 44,014
