Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly, AirPort/Bluetooth Board Assembly: step 1, image 1 of 1
    • Pull the camera cable connector straight out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the optical drive opening.
  2. Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly: step 2, image 1 of 1
    • Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
  3. Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly: step 3, image 1 of 2 Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly: step 3, image 2 of 2
    • Use the tip of a spudger to pry the four antenna connectors up from their sockets on the AirPort/Bluetooth board.
  4. Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly: step 4, image 1 of 3 Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly: step 4, image 2 of 3 Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly: step 4, image 3 of 3
    • De-route all four antenna cables from their channels in the AirPort/Bluetooth housing.
    • De-route the camera cable from its channel in the AirPort/Bluetooth housing.
  5. Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly: step 5, image 1 of 1
    • Remove the following two screws securing the AirPort/Bluetooth assembly to the upper case:
    • One 8.6 mm Phillips screw
    • One 3.9 mm Phillips screw
  6. Installing MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly: step 6, image 1 of 1
    • Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 502
