Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fan
  1. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fan, Lower Case: step 1, image 1 of 1
    • Seven 3 mm Phillips screws.
  2. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fan: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fan, Fan: step 3, image 1 of 1
    • Use the flat end of a spudger to pry the fan cable connector up off its socket on the logic board.
  4. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fan: step 4, image 1 of 1
    • Remove the three identical T6 Torx screws securing the fan to the upper case.
  5. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fan: step 5, image 1 of 1
    • Lift the fan out of the upper case.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 25
All Time: 25,361
