Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Bluetooth Board Replacement (Anti-Glare Option)
  1. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Bluetooth Board Replacement (Anti-Glare Option), Lower Case: step 1, image 1 of 1
    • Seven 3 mm Phillips screws.
  2. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Bluetooth Board Replacement (Anti-Glare Option): step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Bluetooth Board Replacement (Anti-Glare Option), (Anti-Glare Option) Bluetooth Board: step 3, image 1 of 2 Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Bluetooth Board Replacement (Anti-Glare Option), (Anti-Glare Option) Bluetooth Board: step 3, image 2 of 2
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Pull the connector parallel to the face of the logic board, not straight up.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
  4. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Bluetooth Board Replacement (Anti-Glare Option): step 4, image 1 of 2 Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Bluetooth Board Replacement (Anti-Glare Option): step 4, image 2 of 2
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
  5. Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Bluetooth Board Replacement (Anti-Glare Option), Bluetooth Board Replacement (Anti-Glare Option): step 5, image 1 of 1
    • Remove the single Phillips screw securing the Bluetooth board to the retainer.
    • Lift the Bluetooth board off the retainer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 26,010
