MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement
  1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 2, image 2 of 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 3, image 3 of 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Battery Connector: step 4, image 1 of 1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 5, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 5, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 5, image 3 of 3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, I/O Board Cable (Top): step 6, image 1 of 1
    • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
  7. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 7, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 7, image 2 of 2
    • Remove the left connector cover.
    • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
  8. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 8, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 8, image 2 of 2
    • Remove the right connector cover.
    • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
  9. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: step 9, image 1 of 1
    • Peel the top I/O board cable up from the adhesive securing it to the fan.
    • Remove the cable.
Andrew Optimus Goldheart
502,855 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 103
All Time: 8,960
