Nikon Coolpix S5300 LCD Display Screen Replacement
    1. Nikon Coolpix S5300 LCD Display Screen Replacement, Battery: step 1, image 1 of 1
      • Turn the camera upside down and locate the battery compartment.
      • Slide the compartment open following the direction of the arrow.
      Ask FixBot
    2. Nikon Coolpix S5300 LCD Display Screen Replacement: step 2, image 1 of 1
      • Press the orange release button to release and remove the battery.
      • Replace or insert battery in it's respective terminals
      Ask FixBot
    1. Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: step 3, image 1 of 3 Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: step 3, image 2 of 3 Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: step 3, image 3 of 3
      • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
      • Using the same screwdriver, remove the 2 screws on the side of the camera.
      • Remove the 2 screws from the other side of the camera.
      • One of the screws is under the I/O port cover.
      Ask FixBot
    2. Nikon Coolpix S5300 LCD Display Screen Replacement: step 4, image 1 of 3 Nikon Coolpix S5300 LCD Display Screen Replacement: step 4, image 2 of 3 Nikon Coolpix S5300 LCD Display Screen Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to carefully separate the cover from the camera.
      • Work the plastic opening tool around all the edges of the front plate.
      • Pull the purple plastic cover off gently from the screen.
      Ask FixBot
    3. Nikon Coolpix S5300 LCD Display Screen Replacement: step 5, image 1 of 3 Nikon Coolpix S5300 LCD Display Screen Replacement: step 5, image 2 of 3 Nikon Coolpix S5300 LCD Display Screen Replacement: step 5, image 3 of 3
      • Turn the camera over so the LCD screen is facing you.
      • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
      Ask FixBot
    4. Nikon Coolpix S5300 LCD Display Screen Replacement: step 6, image 1 of 2 Nikon Coolpix S5300 LCD Display Screen Replacement: step 6, image 2 of 2
      • Be careful to keep track of little pieces of the outside casing.
      Ask FixBot
    5. Nikon Coolpix S5300 LCD Display Screen Replacement: step 7, image 1 of 2 Nikon Coolpix S5300 LCD Display Screen Replacement: step 7, image 2 of 2
      • Carefully remove the top button casing by pulling it away from main camera.
      Ask FixBot
    1. Nikon Coolpix S5300 LCD Display Screen Replacement, Button Panel: step 8, image 1 of 1
      • Remove the 2 screws on the silver plate
      • Gently lift the screen and silver plate away from the internal components.
      • Do not separate the plate and screen from the camera
      Ask FixBot
    2. Nikon Coolpix S5300 LCD Display Screen Replacement: step 9, image 1 of 2 Nikon Coolpix S5300 LCD Display Screen Replacement: step 9, image 2 of 2
      • Carefully move the button panel away from the silver plate.
      • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap.
      • Safely pull the ribbon cable out and then remove the button panel.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      Ask FixBot
    1. Nikon Coolpix S5300 LCD Display Screen Replacement, LCD Display Screen: step 10, image 1 of 2 Nikon Coolpix S5300 LCD Display Screen Replacement, LCD Display Screen: step 10, image 2 of 2
      • Carefully remove the screen away from the silver plate.
      • Carefully fold the screen over exposing the latch for the ribbon cable.
      Ask FixBot
    2. Nikon Coolpix S5300 LCD Display Screen Replacement: step 11, image 1 of 3 Nikon Coolpix S5300 LCD Display Screen Replacement: step 11, image 2 of 3 Nikon Coolpix S5300 LCD Display Screen Replacement: step 11, image 3 of 3
      • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
      Ask FixBot
    3. Nikon Coolpix S5300 LCD Display Screen Replacement: step 12, image 1 of 1
      • Once the ribbon cable is disconnected, remove the LCD screen.
      Ask FixBot
Waleed Chakir
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 44
Past 30 Days: 122
All Time: 2,247
