Introduction
While it may not be the first component that people gawk over when they see your fancy Retina display MacBook Pro, a nasty looking lower case can be a real eye-sore. Use this guide to help you replace a scratched, scuffed, bent or broken bottom panel.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Set the lower case aside.
