MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement
  1. MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement: step 2, image 1 of 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement, Battery Connector: step 3, image 1 of 1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement: step 4, image 1 of 2 MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement: step 4, image 2 of 2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement, Left Fan: step 5, image 1 of 1
    • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
  6. MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement: step 6, image 1 of 1
    • Remove the following three screws securing the left fan to the logic board:
    • One 4.4 mm T5 Torx screw
    • One 5.0 mm T5 Torx screw with 2 mm collar.
    • One 3.9 mm T5 Wide Head Torx screw
  7. MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement: step 7, image 1 of 3 MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement: step 7, image 2 of 3 MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement: step 7, image 3 of 3
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
    • Lift the left fan out of the device.
Jake Devincenzi
117,381 Reputation
57 Guides authored
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 114
All Time: 43,125
