Installing MacBook Pro 15" Retina Display Mid 2012 I/O Board
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Pro 15" Retina Display Mid 2012 I/O Board, I/O Board: step 1, image 1 of 2 Installing MacBook Pro 15" Retina Display Mid 2012 I/O Board, I/O Board: step 1, image 2 of 2
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable perpendicular to the face of the logic board.
  2. Installing MacBook Pro 15" Retina Display Mid 2012 I/O Board: step 2, image 1 of 2 Installing MacBook Pro 15" Retina Display Mid 2012 I/O Board: step 2, image 2 of 2
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • Carefully lift the I/O board and remove it from the lower case.
Brett Hartt
128,033 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 468
