MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement, AirPort/Camera Cable: step 1, image 1 of 1
    • Use the tip of a spudger to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
  2. MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement: step 2, image 1 of 1
    • Use the tip of a spudger to push the camera cable connector toward the fan and out of its socket on the logic board.
    • Be sure to push parallel to the board, first on one side, then the other, to "walk" the connector out of its socket. Do not pry up, or you will damage the socket.
  3. MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement: step 3, image 3 of 3
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
  4. MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement: step 4, image 1 of 3 MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement: step 4, image 2 of 3 MacBook Pro 15" Retina Display Mid 2012 AirPort/Camera Cable Replacement: step 4, image 3 of 3
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
Brett Hartt
127,974 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,410 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,024
