Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board
  1. Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board, Lower Case: step 1, image 1 of 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board: step 2, image 1 of 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board, Battery Connector: step 3, image 1 of 1
    • Peel back the warning label covering the battery connector.
  4. Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board: step 4, image 1 of 2 Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board: step 4, image 2 of 2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board, AirPort Board: step 5, image 1 of 1
    • Use the tip of a spudger to detach the three antenna connectors up from their sockets on the AirPort board.
  6. Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board: step 6, image 1 of 2 Replacing MacBook Pro 15" Retina Display Early 2013 AirPort Board: step 6, image 2 of 2
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort board to the logic board.
    • Grasp the edges of the board and slide it out from its connector.
    • Lift and remove the AirPort board.
Sam Goldheart
466,565 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,597 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 16,031
