MacBook Pro 15" Core Duo Model A1150 Memory Door Replacement
  1. MacBook Pro 15" Core Duo Model A1150 Memory Door Replacement, Battery: step 1, image 1 of 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core Duo Model A1150 Memory Door Replacement, Memory Door: step 2, image 1 of 1
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
  3. MacBook Pro 15" Core Duo Model A1150 Memory Door Replacement: step 3, image 1 of 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 14
All Time: 15,453
