MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Shield Replacement
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Shield Replacement, Battery: step 1, image 1 of 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Shield Replacement, Battery: step 1, image 2 of 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Shield Replacement, Battery: step 1, image 3 of 3
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Shield Replacement, RAM Shield: step 2, image 1 of 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Shield Replacement, RAM Shield: step 2, image 2 of 2
    • Remove the three identical 2mm PH000 Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 22
All Time: 9,800
